Hi All,
I switched our BeoLab 6000 speakers and bought the new 6002 versions.
In the user menu settings of our BV 7-40 I can’t select the 6002 BeoLab, only the old ones. Is this correct? Or need our BV 7-40 a software update to control the 6002 speakers correctly?
Thanks in advance.
Bas
