Latest post 03-23-2011 10:31 AM by bhollenberg. 2 replies.
Page 1 of 1 (3 items)
  • 03-23-2011 9:31 AM
    Update SW BeoVision 7-40 with new BeoLab 6002 speakers?
    Hi All,
    I switched our BeoLab 6000 speakers and bought the new 6002 versions.
    In the user menu settings of our BV 7-40 I can’t select the 6002 BeoLab, only the old ones. Is this correct? Or need our BV 7-40 a software update to control the 6002 speakers correctly?
    Thanks in advance.
    Bas
    My Bang & Olufsen....
    • BeoVision 7-40 MK V
    • BeoSound 5
    • BeoMaster 5
    • BeoLab 6002 (2*)
    • BeoLab 7-4
    • BeoLab 4 (2*)
    • BeoLab 11
    • BeoCom 4
    • Beo 5
  • 03-23-2011 10:19 AM In reply to
    Re: Update SW BeoVision 7-40 with new BeoLab 6002 speakers?
    The 6000 setting will be absolutely fine - there is no performance difference. No doubt a future upgrade will change the menus so that the 6002 can be selected but I doubt there will be any material change.
  • 03-23-2011 10:31 AM In reply to
    Peter :
    So the fact that the 6002 Series has a different amplifier (and more power) as the 6000 series, will therefore make no difference in controlling them?
    Kind regards,
    Bas
    • BeoSound 5
    • BeoMaster 5
    • BeoLab 6002 (2*)
    • BeoLab 7-4
    • BeoLab 4 (2*)
    • BeoLab 11
    • BeoCom 4
    • Beo 5
