1st March February 2012
03-23-2011 4:15 AM
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
B&O MMC10 E? Have I missed something?
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
wirralsimon
- Joined on 04-17-2007
- Birkenhead, UK
- Posts 1,253
Re: B&O MMC10 E? Have I missed something?
I belive the MMC20 series were briefly sold as the MMC10 in the USA but they are basically the same cartridges.
Simon
Søren Hammer
- Esbjerg/Denmark
- Posts 554
They look similar, the only difference being the plastic guard over the needle which is black instead of transperant.
Eugene
- Joined on 12-17-2008
- Posts 589
Simon may be correct, You see them on eBay over here from time to time. I seem to remember it was sold as a replacemnt cartridge from the late 80 into the 90's.
It was not part of the original series.
beaker
- Joined on 06-14-2007
- Posts 526
I have a UK price list from March 1982 that states that the Beogram 1700 came equipped with an MMC10E and it cost £99 all in. The list is from Nottingham Sound and Vision.
Peter
- Joined on 02-12-2007
- Posts 9,572
I never saw a 10E for sale in the UK but it seemed to be the bottom of the range in the US replacing the 20S. In any case, it is a perfectly acceptable cartridge! Of course you can get Axel to replace the cantilever and make it whatever you want!
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Hehe, I was just wondering, they look quite odd as they weren't a part of the Danish catalogue. I am in plenty of MMC20-style carts for now, just buying cheap non-working Beograms (there is a surprising amount of Beogram 1902's over here) with fine carts if they are needed
Page 1 of 1 (7 items)
