Latest post 03-23-2011 3:24 PM by Søren Hammer. 6 replies.
Page 1 of 1 (7 items)
  • 03-23-2011 4:15 AM
    B&O MMC10 E? Have I missed something?
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 03-23-2011 5:38 AM In reply to
    Re: B&O MMC10 E? Have I missed something?
    I belive the MMC20 series were briefly sold as the MMC10 in the USA but they are basically the same cartridges.
    Simon
  • 03-23-2011 5:48 AM In reply to
    They look similar, the only difference being the plastic guard over the needle which is black instead of transperant.
  • 03-23-2011 6:01 AM In reply to
    Simon may be correct, You see them on eBay over here from time to time. I seem to remember it was sold as a replacemnt cartridge from the late 80 into the 90's.
    It was not part of the original series.
  • 03-23-2011 8:29 AM In reply to
    I have a UK price list from March 1982 that states that the Beogram 1700 came equipped with an MMC10E and it cost £99 all in. The list is from Nottingham Sound and Vision.
  • 03-23-2011 9:18 AM In reply to
    I never saw a 10E for sale in the UK but it seemed to be the bottom of the range in the US replacing the 20S. In any case, it is a perfectly acceptable cartridge! Of course you can get Axel to replace the cantilever and make it whatever you want!
  • 03-23-2011 3:24 PM In reply to
    Hehe, I was just wondering, they look quite odd as they weren't a part of the Danish catalogue. I am in plenty of MMC20-style carts for now, just buying cheap non-working Beograms (there is a surprising amount of Beogram 1902's over here) with fine carts if they are needed Big Smile
