Latest post 03-22-2011 7:17 PM by Steffen. 3 replies.
Page 1 of 1 (4 items)
  • 03-20-2011 5:16 PM
    • Shawn
    • Not Ranked
    • Joined on 03-20-2011
    • Portland, Or. USA
    • Posts 2
    P45 grills.......
    Mine seemed to be glued on...but some pictures I've seen shows "plugs" of sorts. Does the model vary in the grill attactment?
    Filed under: , , ,
  • 03-20-2011 6:17 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: P45 grills.......
    Well, unless someone has done so in the past they should not be glued! They can feel very stiff. I carefully ease the panels off at each peg a little at a time... I have heard it mention to spray silicon oil in the pegs but never tried with the grills on.
    Olly.
  • 03-22-2011 2:48 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Both ways of mounting can be found.
    Work carefully when taking off the grills, they break easily, typically across the center.
  • 03-22-2011 7:17 PM In reply to
    -and I thought that it was only the M70's that had two ways of mounting Hmm
    I have the "old" version with the glued grills. Damned job to remove them -and glue them back on again...Super Angry
