Latest post 04-04-2011 1:14 PM by Step1. 10 replies.
Page 1 of 1 (11 items)
  • 03-19-2011 4:43 PM
    BEOGRAM 4002 RUN TO FAST
    Hi all,
    I've bought a second Beogram 4002 Type 5521 in almost MINT condition. Unfortunally the motor run to fast (over 10 seconds per minute). How can i calibrate the speed? All other functions are working good...
    Thanks!
    Filed under:
  • 03-19-2011 6:36 PM In reply to
    Re: BEOGRAM 4002 RUN TO FAST
    Upgrade to silver or gold membership and download the service manual. Page 4-1 describes speed adjustment.
    You will need a stroboscopic disc, available to buy or download on the internet.
    Regards Graham
  • 03-19-2011 8:05 PM In reply to
    Strobo discs here
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 03-20-2011 1:35 PM In reply to
    Thanks for the quick and helpful answers.
    I've already the schematic...
    My questions: Is this job easy to do for a non technican? Which strobo disc i have to use in Europe the 50 Hz? Will the strobo disc work with a Maglite Flashlight?
    Best Regards
  • 03-20-2011 2:31 PM In reply to
    I just use  a desk light plugged into the 50Hz mains. Works OK for me.
    Turn the appropriate potentiometer until the speed is correct. Easy!
    Regards Graham
  • 03-20-2011 6:22 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    It is important that the lamp flickers at 50 (100hz) this means a standard tungsten filament lamp should be used. A traditional ballast flo tube would be ok but not modern electronically controlled stuff.
    Olly.
  • 03-21-2011 12:31 AM In reply to
    joeyboygolf:
    Jow, I use a normal lamp 60 Hz
  • 03-23-2011 4:19 PM In reply to
    Thanks! I'll try it at the Weekend...
    Best Regards
  • 03-23-2011 5:34 PM In reply to
    Remember you are 50 Hz
  • 04-02-2011 7:03 PM In reply to
    Update: It works and it was easy to adjust also for a non technican.
    One question about the speed of the stroboscop-disc. There is a 33.33 (33 1/3) and a 45.11 (45). Why is it 45.11 and not exactly 45?
    Thanks for the advice.
  • 04-04-2011 1:14 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Because unfortunately the number of whole stripes for 45rpm are not a multiple of 50hz so this is the closest you get in the UK using this method.
    Good enough for most and I wonder do / did record manufacturers make allowances for this?
    Olly.
