1st March February 2012
Latest post 04-04-2011 1:14 PM by Step1. 10 replies.
03-19-2011 4:43 PM
superdario
- Joined on 06-21-2009
- Zurich / Switzerland
- Posts 152
Hi all,
I've bought a second Beogram 4002 Type 5521 in almost MINT condition. Unfortunally the motor run to fast (over 10 seconds per minute). How can i calibrate the speed? All other functions are working good...
Thanks!
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
Re: BEOGRAM 4002 RUN TO FAST
Upgrade to silver or gold membership and download the service manual. Page 4-1 describes speed adjustment.
You will need a stroboscopic disc, available to buy or download on the internet.
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
superdario
- Posts 152
Thanks for the quick and helpful answers.
I've already the schematic...
My questions: Is this job easy to do for a non technican? Which strobo disc i have to use in Europe the 50 Hz? Will the strobo disc work with a Maglite Flashlight?
Best Regards
joeyboygolf
- Posts 3,252
I just use a desk light plugged into the 50Hz mains. Works OK for me.
Turn the appropriate potentiometer until the speed is correct. Easy!
Søren Mexico
- Mexico city
- Posts 1,621
joeyboygolf:
Jow, I use a normal lamp 60 Hz
Søren Mexico
- Mexico city
- Posts 1,621
Step1
- Joined on 07-06-2008
- Manchester
- Posts 961
Because unfortunately the number of whole stripes for 45rpm are not a multiple of 50hz so this is the closest you get in the UK using this method.
Good enough for most and I wonder do / did record manufacturers make allowances for this?
Page 1 of 1 (11 items)
