Probably lack of a decent seal in the cylinder iteself. This would have originally been accomplished with some sort of hydraulic based oil I believe.
Carefully pull the plunger out (after releasing the upper arm from pivot), give it a good clean, then use a small drop of quality sewing machine oil - not 3in1!!!
That should sort it!
