Latest post 03-18-2011 1:55 PM by Step1. 4 replies.
Page 1 of 1 (5 items)
  • 03-16-2011 9:48 PM
    • Skyit2
    • Not Ranked
    • Joined on 03-10-2011
    • Posts 3
    • Silver Member
    BeoGram 4004 Pick arm speed
    I have (2) BG 4004 turntables and the pickup arm drops at different rates, one is perfect and the other is too fast.  I adjusted the damper cylinder screw and it is turned all the way in.  This did help but still too fast.  Is there another adjustment that would help or is the cylinder bad?  If it is bad can it be reworked?
    Filed under:
  • 03-17-2011 6:37 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: BeoGram 4004 Pick arm speed
    Probably lack of a decent seal in the cylinder iteself. This would have originally been accomplished with some sort of hydraulic based oil I believe.
    Carefully pull the plunger out (after releasing the upper arm from pivot), give it a good clean, then use a small drop of quality sewing machine oil - not 3in1!!!
    That should sort it!
    Olly.
  • 03-17-2011 12:12 PM In reply to
    • Skyit2
    • Not Ranked
    • Posts 3
    • Silver Member
    Sounds simple enough, Thanks
  • 03-17-2011 2:49 PM In reply to
    • Skyit2
    • Not Ranked
    • Posts 3
    • Silver Member
    This was the simplest adjustment to this turntable ever, it looked more complicated than it was. Just as you said, clean piston, oil it.  10 minute repair, THANKS
  • 03-18-2011 1:55 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Nice to get feedback, glad all is working again :)
    Olly.
