How can I change 16:9 view to 4:3 view on Beovision MX 7000? It shows on most programms 16:9 view, on some 4:3. I woluld like to enlarge the view to 4:3 on all programms. Is there a menue setting to change it by Beo4 or Beolink 1000?
you using a freeview or satellite boix if so do it on the box settings menus
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
I am using cable, there is no box. so I have to change at the TV.
If theres no setup system with the cable box I think so!
tony s
So I´m looking for the setup way at TV, is there a opertunity to enlarge or zoom the pictureview?
it has tyo done external to the tv the tv will then produce the relevant sized picture, bear in mind it is an old tv relatively speaking
t
BeoVision MX7000 can't change picture formats. So I am sorry to say that the answer is no, you can't change the format on an MX7000.
