Latest post 03-14-2011 3:26 PM by Blackrix. 6 replies.
Page 1 of 1 (7 items)
  • 03-12-2011 12:34 PM
    Beovision MX7000 change 16:9 to 4:3 ???
    How can I change 16:9 view to 4:3 view on Beovision MX 7000? It shows on most programms 16:9 view, on some 4:3. I woluld like to enlarge the view to 4:3 on all programms. Is there a menue setting to change it by Beo4 or Beolink 1000?
  • 03-12-2011 12:55 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Beovision MX7000 change 16:9 to 4:3 ???
    you using a freeview or satellite boix if so do it on the box settings menus
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 03-13-2011 7:26 AM In reply to
    I am using cable, there is no box. so I have to change at the TV.
  • 03-13-2011 7:48 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    If theres no setup system with the cable box I think so!
    tony s
  • 03-14-2011 11:20 AM In reply to
    So I´m looking for the setup way at TV, is there a opertunity to enlarge or zoom the pictureview?
  • 03-14-2011 12:13 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    it has tyo done external to the tv the tv will then produce the relevant sized picture, bear in mind it is an old tv relatively speaking
    t
  • 03-14-2011 3:26 PM In reply to
    BeoVision MX7000 can't change picture formats. So I am sorry to say that the answer is no, you can't change the format on an MX7000.
