Good afternoon,
I need some help with my MPAV 9000, which I have used very well so far with my BeoVision Avant 32DVD, via Beo4.
How do I put it in Service Mode, such that I can also manually command it? I have read on this forum that two pins have to be soldered together near the ML connector, but I want to make sure to do the right thing...
Any help would be appreciate it, thank you very much.
Best Regards,
Sebastiano
P.S. If anybody has a swift idea on how to connect a BeoGram 7000 directly to a BV 7-40 (remote controllable), I would greatly appreciate to hear it! On the German forum, response rate has been.... zero unfortunately so far!
