Latest post 03-07-2011 6:55 AM by kimhav. 1 replies.
Page 1 of 1 (2 items)
  • 03-06-2011 1:56 PM
    BeoVision 8-40 hz question
    Hi guys,
    I have a question regarding my BeoVision 8-40. I have the version with 100/120 hz refresh rate.
    Does the television itself change from 100 hz to 120 hz, when I choose between PAL and NTSC on my MacMini ? Or is it the 'FILM MODE' which changes the television the 120 hz ?
    I was the second place winner on the BeoWorld May 2009 Prize Draw!
    Thanks to BeoWorld for a great site!
  • 03-07-2011 6:55 AM In reply to
    • kimhav
    • Top 500 Contributor
    • Joined on 09-03-2007
    • Sweden
    • Posts 127
    Re: BeoVision 8-40 hz question
    The film mode senses automatically the incoming signal trough the HDMI port, but only if the source allows it, that means that your MacMini needs to support 24p output to be able to make use this feature.
    Filed under: , ,
