No alcohol does mean no alcohol. Properly formuated ar cleaners use alcohol as an agent to facilitate uniform drying, which helps reduce streaking.
No straight alcohol. As far as cleaners, the lack of knowledge as to just how much alcohol is in any cleaner is the reason behing beocare's mild detergent recommendation.
Adequate, but not the best you can do.
I like Nanocare products.
B
