Latest post 03-06-2011 4:33 AM by elephant. 4 replies.
Page 1 of 1 (5 items)
  • 03-06-2011 1:00 AM
    resetting a MCP (particularly a 5000)
    Is there a way to reset a MCP to the factory defaults?  I bought a Beosystem 5000 that came with a MCP 5000 while contemplating repairing my 6500.  The 5000 doesn't work with the Beo 4 so it's good that it has a built-in panel.  The MCP 5000 seems to have some settings from the prev owner.  For instance, when I hit the Treble key, it turns off the Beomaster.  Obviously, that is unintentional.  Therefore, I'd like to get it back to the original, default settings.   Thanks in advance.
    Glenn
  • 03-06-2011 2:41 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: resetting a MCP (particularly a 5000)
    The Master Control Panel holds no settings, it's all in the Beomaster.
    You can take out the MCP batteries, leave it for a while and reinsert
    to reset the processor inside the MCP but there's no guarantee that it will cure the fault.
    To me it sounds more like a matter of cleaning the buttons. It doesn't take much dust or a drop of
    something spilled to bind a button and they have a tendency to stick in an almost down position
    after being pressed, which occasionally leaves the MCP sensitive to mere touching.
    In this case, I would check around the standby button in particular. Is it producing a nice click when pressed and
    does it come all the way back up again etc.
  • 03-06-2011 3:04 AM In reply to
    Thanks.  I hadn't noticed any sticking or clicks.  However, I notice that when I push buttons the word 'Battery' appears as well.  I wasn't sure if that was normal and I thought I was using relatively, fully-charged batteries(?)  If that's not normal, that could be an issue as well, right?
  • 03-06-2011 4:02 AM In reply to
    Also, I don't see a Standby button on the MCP 5000.
  • 03-06-2011 4:33 AM In reply to
    rtg497:
    On all (most?) B&O equipment the standby button is the orange/red dot button
    [●] voila Laughing
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
