Is there a way to reset a MCP to the factory defaults? I bought a Beosystem 5000 that came with a MCP 5000 while contemplating repairing my 6500. The 5000 doesn't work with the Beo 4 so it's good that it has a built-in panel. The MCP 5000 seems to have some settings from the prev owner. For instance, when I hit the Treble key, it turns off the Beomaster. Obviously, that is unintentional. Therefore, I'd like to get it back to the original, default settings. Thanks in advance.
Glenn
