Latest post 03-07-2011 6:28 PM by DigitalKnight. 6 replies.
Page 1 of 1 (7 items)
  • 03-05-2011 7:50 PM
    Boelink 7000 remote / charging dock
    I can not get the remote to respond or wake up? There are three pins on the charging base but I get no voltage measurement on any of them?
    Looks like a 9 volt charging system?
  • 03-06-2011 9:23 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Boelink 7000 remote / charging dock
    DigitalKnight:
    Welcome to BeoWorld!
    I have seen some people break apart their charging bases before here on the forum. Do a quick search on the forum and double check the "Workbench" section.
    Evan
  • 03-07-2011 4:01 AM In reply to
    Yeah, you should have about 9 volts between some charger pins, can't remember which (two of them are connected internally by a resistor).
    There is a 100 mA canned style plug in fuse (looks like a brown electrolytic cap) in the charger and it might be blown.
    Since you're at 110V, the fuse might actually have a different rating - replace with whatever value you find in your charger now.
    -mika
  • 03-07-2011 4:28 PM In reply to
    Maybe this can help, you know what they say, pictures says more...
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 03-07-2011 4:58 PM In reply to
    Thank you! Pics were perfect! Got dock to work.... and now the 7000 powers up... but only when on the dock so it looks like the rechargeable battery pack is dead....
    Best place to pick up a replacement battery pack?
    Thanks again for all the help.
    Mark
  • 03-07-2011 6:21 PM In reply to
    Ebay perhaps?
  • 03-07-2011 6:28 PM In reply to
    I did check eBay but I did not think to check out of the USA... Thanks.
