Latest post 03-05-2011 5:38 PM by Evan. 6 replies.
Page 1 of 1 (7 items)
  • 03-05-2011 12:01 PM
    Active speakers and Beomaster 4500
    Hi Forum
    Will my old Beomaster 4500 be able to use newer speakers like Beolab 4 and Beolab 3500?
  • 03-05-2011 12:08 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Active speakers and Beomaster 4500
    Welcome to BeoWorld!
    To answer your question - Yep!
    Yes -  thumbs up
    Evan
  • 03-05-2011 12:09 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Yes there should be no problem in using it.
    There are two pl outputs on the BM4500.
    One issue though, should be the type of pl cable to use but I'm not sure about this
    Best regards
    Spiros
  • 03-05-2011 12:12 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    I think fully wired MK2 would be the best bet?
    pl = Powerlink
    Evan
  • 03-05-2011 12:26 PM In reply to
    Depends on the speakers rather than the 4500 as to which cable you will need. They will all work though.Speakers with ICE amplifiers need cables with more screening.
  • 03-05-2011 12:29 PM In reply to
    Thanks for quick reply.
    Do I need Mrk II og Mrk III cabels?
    What would you prefere as a small speaker for BN4500?
  • 03-05-2011 5:38 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Well, technically, MK3 if you want BeoLab 4.
    I'm sure MK3 is backwards compatible, so go with that one.
    As far as active (BeoLab) speakers, any are approprite. Whatever is best for your space and for you. The usual suspect around here is the BeoLab 3000. But those can be a bit large still and limited to wall placement. A LOT of people like the 4000 which is quite compact. There are a bunch of options...
    Evan
