1st March February 2012
Latest post 03-03-2011 10:15 PM by Razlaw. 12 replies.
03-02-2011 10:05 PM
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Beosound 5 set up question
I am setting up my new Beosound 5. I made all of the connections and plugged the unit in. The screen came on with the initial set up menu. Before I could do anything with it the menu disappeared and the screen went blank. All it does now is the red standby light flashes. Any thoughts?
I can call the dealer tomorrow of course but they are closed for the day now.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Razlaw
- Illinois
- Posts 1,770
Re: Beosound 5 set up question
Weird, after staring at a blank screen for an hour, all of a sudden it came to life properly
Heribert
- Joined on 08-06-2009
- Austria
- Posts 592
it is a PC...
Hope it turned to work well after this recovery.
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
It's like adopting a cat. It has to get used to the place.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
Razlaw
- Illinois
- Posts 1,770
TripEnglish:
LOL That seems like exactly what it was. Now if I can just get the wireless adapter to work. Unfortunately my router is on a different floor in the house and to run an ethernet cable would require multiple holes in multiple walls. Wireless adapter has software that needs to be installed so I guess I need to connect an external CD/DVD drive to the Beomaster and install the software?
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
Have you considered "Ethernet over mains"?
Used it a few times and seems a good solution.
Opman
Razlaw
- Illinois
- Posts 1,770
linder
- Joined on 04-16-2007
- Posts 653
As an alternate to a wireless adapter, use a wireless network bridge and connect to the ethernet port on the Beomaster 5. I am using an airport express as a wireless bridge. Other inexpensive wireless routers can function as a bridge. Cisco and Linksys are the brands that I have tried. There are others
If you use an wireless adapter on the Beomaster 5, you will need to attach a keyboard and monitor to the Beomaster and install the driver as is normally done in Windows XP.
I hope this helps.
Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002 BL11
linder
- Posts 653
Razlaw:
It is a way of using your house electrical wiring to transmit ethernet data. This is not usually done in the US but does work.
Razlaw
- Illinois
- Posts 1,770
linder:
I hope this helps.
I am using an Airport Extreme as a base. Are you saying all I need to do is connect an Airport Express to the Beomaster 5?
linder
- Posts 653
Razlaw:
linder:
I hope this helps.
Yes! Use the ethernet port on the Airport Express and then plug the cable into the BM5. Setup the AE to join a wireless network by entering the name of the wireless network of the Airport Extreme. I use WPA2 personal for security which matches the setting I use on the AE. I have been running this way for almost 2 years.
Razlaw
- Illinois
- Posts 1,770
Once again, Apple works. After fighting with a non-Appple wifi adapter with no luck, tried Airport Express and had success quickly.
Razlaw
- Illinois
- Posts 1,770
Beosound 5 is up and running. It is wonderful. Sound is much better than the sound from the iMac I had been using for Net Music.
Page 1 of 1 (13 items)
