Latest post 03-03-2011 10:15 PM by Razlaw. 12 replies.
Page 1 of 1 (13 items)
  • 03-02-2011 10:05 PM
    Beosound 5 set up question
    I am setting up my new Beosound 5. I made all of the connections and plugged the unit in. The screen came on with the initial set up menu. Before I could do anything with it the menu disappeared and the screen went blank. All it does now is the red standby light flashes. Any thoughts?
    I can call the dealer tomorrow of course but they are closed for the day now.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 03-02-2011 10:50 PM In reply to
    Re: Beosound 5 set up question
    Weird, after staring at a blank screen for an hour, all of a sudden it came to life properly
  • 03-03-2011 2:15 AM In reply to
    it is a PC... Wink
    Hope it turned to work well after this recovery.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 03-03-2011 6:21 AM In reply to
    It's like adopting a cat. It has to get used to the place.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 03-03-2011 8:11 AM In reply to
    TripEnglish:
    LOL     That seems like exactly what it was. Now if I can just get the wireless adapter to work. Unfortunately my router is on a different floor in the house and to run an ethernet cable would require multiple holes in multiple walls. Wireless adapter has software that needs to be installed so I guess I need to connect an external CD/DVD drive to the Beomaster and install the software?
  • 03-03-2011 10:19 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Have you considered "Ethernet over mains"?
    Used it a few times and seems a good solution.
    Opman
  • 03-03-2011 10:43 AM In reply to
    What is that?
  • 03-03-2011 11:49 AM In reply to
    As an alternate to a wireless adapter, use a wireless network bridge and connect to the ethernet port on the Beomaster 5.  I am using an airport express as a wireless bridge. Other inexpensive wireless routers can function as a bridge.  Cisco and Linksys are the brands that I have tried.  There are others
    If you use an wireless adapter on the Beomaster 5, you will need to attach a keyboard and monitor to the Beomaster and install the driver as is normally done in Windows XP.
    I hope this helps.
    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
  • 03-03-2011 11:54 AM In reply to
    Razlaw:
    What is that?
    It is a way of using your house electrical wiring to transmit ethernet data.  This is not usually done in the US but does work.
  • 03-03-2011 12:43 PM In reply to
    linder:
    I hope this helps.
    I am using an Airport Extreme as a base. Are you saying all I need to do is connect an Airport Express to the Beomaster 5?
  • 03-03-2011 1:20 PM In reply to
    Razlaw:
    linder:
    I hope this helps.
    Yes!  Use the ethernet port on the Airport Express and then plug the cable into the BM5.  Setup the AE to join a wireless network by entering the name of the wireless network of the Airport Extreme.  I use WPA2 personal for security which matches the setting I use on the AE.  I have been running this way for almost 2 years.
  • 03-03-2011 7:55 PM In reply to
    Once again, Apple works. After fighting with a non-Appple wifi adapter with no luck, tried Airport Express and had success quickly.
  • 03-03-2011 10:15 PM In reply to
    Beosound 5 is up and running. It is wonderful. Sound is much better than the sound from the iMac I had been using for Net Music.
