        1st March February 2012
	    Latest post 03-06-2011 4:09 PM by  kimhav. 14 replies.
								        03-02-2011 3:17 AM
									        avus17
								                - Joined on 04-16-2007
								                - Posts 336
										    BeoSound 5 Encore and connection to TV
										    Does anybody already know how the new BeoSound 5 Encore will be connected to the TV as a part of fully integated system as it will not have any ML connection?
Can we expact new televisions with Ethernet connection with Audio systens in the future?
									        bayerische
								                - Joined on 12-11-2007
								                - Helsinki, Finland
								                - Posts 3,593
										    Re: BeoSound 5 Encore and connection to TV
										    What I understood from my dealer, the Encore is a standalone product...?
									    -Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
									        Opman
								                - Joined on 12-31-2007
								                - Cheshire, UK
								                - Posts 323
										      bayerische:
It will be possible to connect up to 8 BeoSound5 Encores to one central BeoMaster5 or NAS drive and all will be able to play independently. So not really a stand alone system.
The Encores will be networked via a router. Later this year there will be an interface box that will allow Network Link to connect to an existing ML system. Rather like an ML/MCL is used to allow to different link systems to join up. Thereby allowing the BeoSound5 Encore to be part of a system that has Video products using ML.
Opman
									        PhilLondon
								                - London
								                - Posts 2,545
										    Both of yor are right... B&O will present it as a standalone system until they provide the converter and/or compatible TVs.
It is a shame they are not more open about what will be the capabilities of this new Beonet system.
									        Karel Uyttendaele
								                - Joined on 05-19-2007
								                - Aalst, Belgium
								                - Posts 682
										    At launch it will just be a stand alone product.. with the possibility to connect to other Beonet devices in the future.. They have to start somewhere... Just see it as a first product of a new generation..
									    The race for quality has no finish line- so technically, it's more like a death march.
									        bhollenberg
								                - Joined on 09-21-2009
								                - Amsterdam
								                - Posts 27
										    If I look on the B&O website and check the specifications, it looks that the BeoSound 5 already have these things:
http://www.bang-olufsen.com/specifications?productid=637
Isn't it just a software update?
Gr. Bas
									    My Bang & Olufsen....
- BeoVision 7-40 MK V
- BeoSound 5
- BeoMaster 5
- BeoLab 6002 (2*)
- BeoLab 7-4
- BeoLab 4 (2*)
- BeoLab 11
- BeoCom 4
- Beo 5
									        Vienna
								                - Joined on 08-15-2008
								                - make an educated guess
								                - Posts 712
										      bhollenberg:
A BeoSound 5 will ALWAYS need a BeoMaster5 as content server and PL-Controller for local active speakers    (and the BM5 can additionaly connect to a NAS via Ethernet, distribute sound to a ML-System, deliver pictures  to a tv, ...)
  The BeoSound 5 ENCORE will be a PL-Controller for local active speakers, a Local Input Selector, a Display,  a "Mouse" (beeing just a Network CLIENT it will need a storage like a NAS, PC/MAC,  Mediaserver or a  BeoMaster 5 to access content via Ethernet)
You will be able to use a BeoSound 5 + Beomaster 5 or a BeoMaster 5 + TV as a content server for several  BeoSound 5 Encores beeing connected via Ethernet.
									        bhollenberg
								                - Amsterdam
								                - Posts 27
										    Thanks for the reply, it makes a lot clear to me!
If you use the BeoSound 5 ENCORE as a stand alone product. Are you still able to control it through a remote?
Gr. Bas
- BeoSound 5
- BeoMaster 5
- BeoLab 6002 (2*)
- BeoLab 7-4
- BeoLab 4 (2*)
- BeoLab 11
- BeoCom 4
- Beo 5
									        Vienna
								                - Posts 712
										      bhollenberg:
Yes, it 's a music system able to control lokal speakers, getting content from remote sources via ethernet.
  If you imagine it in terms of an "analog ML-System" it could be described as something like an "Ethernet  BeoLink Active with integrated IR receiver, more local inputs plus a great display plus a great navigation for digital content delivered from local sources, a remote storage or the internet"
									        TWG
								                - Joined on 04-17-2007
								                - Germany
								                - Posts 950
										    Did I understood it correctly:
  I could use several Beosound 5 Encores as a remote / remote-screen for the existing Beosound 5?
  e.g.: Beosound 5 in the living room, Beosound 5 Encore in the office to access the Beomaster 5 content, see what's playing on the Beosound 5, navigate etc.?
  That would be very nice.
									        vlohjr1
								                - Joined on 06-26-2007
								                - Posts 106
										    This is effectively a very very expensive sonos the encore costs say 2500 pounds whereas a sonis player is 280. However encore is beautifully finished product Does anyone know when integration with tv is available I would not buy it standalone when it comes out without integration initiallyCheersVince
									        Vienna
								                - Posts 712
										      TWG:Did I understood it correctly
Yes & No
Every BeoSound 5 Encore will access a common storage (eg BM5) or the same router/access point and will  independently play the selected content in it's own room through it's own speakers  - it's a music system, not a remote!.
    It's ethernet, not (only one source at the same time) MasterLink  - different "NetMusic" /  "NetRadio"  in every room from the same storage / via the same router/access point.
Disadvantage at the moment will be, "old" ML-sources like "CD", "RADIO", "TV/DTV", ... can not be accessed till a  NWL/ML (NetWorkLink <> MasterLink) converter becomes available and these sources can be converted from analog ML to digital NWL.
									        Vienna
								                - Posts 712
										      vlohjr1:a very very expensive sonos the encore costs say 2500 pounds whereas a sonis player is 280
... a Bentley and a Skoda have in common: they are cars, are using roads and beeing owned by VW
- but will offer a slightly different "user interface" & "driving experience" ...
									        akoro
								                - Joined on 08-07-2008
								                - Espoo, Finland
								                - Posts 88
										      Vienna:
Brilliant comparison. I have been trying to use AppleTV as a digital media player for music instead of BeoMedia and oh boy what a difference that is. It's like using Wengler tool instead of a proper kitchen knife for cutting vegetables. I really like all the video abilities of ATV but the navigation for music just sucks compared to B&O solution where you can change sorting with one press of a Beo4 button
									        kimhav
								                - Joined on 09-03-2007
								                - Sweden
								                - Posts 127
										    In regards of choosing between BS5+BM5 and BS5 Encore; are there any reason one would go for BS5+BM5 solution? Reason for asking is that the BM5 box for me it's just something that I would hide away and not even connect to a BV; I mean the BeoPlayer is just plain crap. It was nice when they released it and I'm currently making use of a BeoPort solution with a specific media pc (using same mobo as BeoMedia).
Seems that the price for BS5 Encore seems to land around 3400 euro which means that one have to add for the ML2BeoNet box as well including waiting for this box to be available.
Also I'm really curious about the hw+sw itself when it comes to updates; but that we just have to wait for to get more information.
        Page 1 of 1 (15 items)
