Hi all!
I am a lucky owner of a BV3-32 and a AV9000, and I am using Apple TV and also digital "on demand" TV a lot through settop boxes.
In my current configuration I am using "v.mem" / "v.tape" assigned to Apple TVs and "v.aux" in the list menu for the STB.
All works fine and its also controlled perfectly via a Lintronic box, since none of the TVs are equipped with a built in STB controller card.
But, it annoys me that I can't figure out how to assign the digital box ( I have one Motorola for the BV-3 and a Sagem for the AV9000) to the DTV button? Or the SAT button for the BEO4 for the AV 9000. DTV and SAT are basically the same function, right?
The scarts can be assigned with Decoder, V.TAPE or NON B&O and it works fine using v.mem, v.tape (2) DVD2 etc, using the list menu, but since there now is a DTV (SAT) button on the remote, how do I assign it to one of the scarts?
Any input is velcome..
/Peter
