Latest post 03-02-2011 3:56 AM by Peter. 8 replies.
Page 1 of 1 (9 items)
  • 03-01-2011 6:33 AM
    • Peter
    • Top 500 Contributor
    • Joined on 12-28-2009
    • Sweden
    • Posts 134
    Using DTV / SAT on a BEO4 with BV3-32 and AV9000, what do I need?
    Hi all!
    I am a lucky owner of a BV3-32 and a AV9000, and I am using Apple TV and also digital "on demand" TV a lot through settop boxes.
    In my current configuration I am using "v.mem" / "v.tape" assigned to Apple TVs and "v.aux" in the list menu for the STB.
    All works fine and its also controlled perfectly via a Lintronic box, since none of the TVs are equipped with a built in STB controller card.
    But, it annoys me that I can't figure out how to assign the digital box ( I have one Motorola for the BV-3 and a Sagem for the AV9000) to the DTV button? Or the SAT button for the BEO4 for the AV 9000. DTV and SAT are basically the same function, right?
    The scarts can be assigned with Decoder, V.TAPE or NON B&O and it works fine using v.mem, v.tape (2) DVD2 etc, using the list menu, but since there now is a DTV (SAT) button on the remote, how do I assign it to one of the scarts?
    Any input is velcome..
    /Peter
    Filed under: , ,
  • 03-01-2011 6:46 AM In reply to
    Re: Using DTV / SAT on a BEO4 with BV3-32 and AV9000, what do I need?
    You will not be able to assign DTV button to anything. That is a limitation in the BV3. That is changed in later Beovisions, where DTV can be assigned to any input. In e.g. BV10 you also can assign the TV button to other inputs, than the built in digital tuner.
    /Claes
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 03-01-2011 7:26 AM In reply to
    • Peter
    • Sweden
    • Posts 134
    Thanks for your quick reply, Claes!
    So then I assume it's definitly not possible to use on an older AV9000 either :(
    Not the answer I was hoping for, but at least I can stop messing around with it and settle for using the commands in the "list" menues.. :-)
    /Peter
  • 03-01-2011 7:43 AM In reply to
    Peter:
    I´m sure it´s the same thing with your AV9000.
    _____________
  • 03-01-2011 2:47 PM In reply to
    • lano
    • Not Ranked
    • Joined on 04-25-2010
    • Posts 66
    • Gold Member
    On my BV3-32 I can assign STB (and also PC) on the connection menu, so it will start by pressing the SAT button on the Beo4. I think it's related to the software version.
  • 03-01-2011 3:30 PM In reply to
    • Peter
    • Sweden
    • Posts 134
    Hi lano,
    Interesting, definitly sounds like a matter of which release it is then…
    What is your release?..and where can I see the it?
    Thanks,
    Peter
  • 03-01-2011 3:51 PM In reply to
    • lano
    • Not Ranked
    • Posts 66
    • Gold Member
    Hi, I have a type 8810 with software version 16.3. I also have a STB contoller (I dont't know if this matter). You can find the software version by pressing menu->setup->00 GO->monitor
  • 03-02-2011 1:08 AM In reply to
    • Peter
    • Sweden
    • Posts 134
    Hi Lano,
    It turns out I have : 06 IC3 (AP): SW  8.6  and 06 IC2 (IOP): SW 22.0  and 32 IC607 (AC3): SW 1.8   EPROM ver. 011 and my Type is: 8800
    So I assume my set is older than yours..
    I'll have a word with my dealer about an upgrade, I hope he can do it in my home, moving those 80 Kg is no fun… ;-)
    Thanks for your help, Iano!
    /Peter
  • 03-02-2011 3:56 AM In reply to
    • Peter
    • Sweden
    • Posts 134
    ...btw..does anyone know what AP and IOP is? I assume AC3 is the software revision for the surround module, am I right?
    Also, It would be interesting to know what features or fixes i would get if upgrading,  more than just being able to use the DTV button..
    Thanks,
    Peter
