1st March February 2012
Latest post 04-27-2011 1:25 PM by HVD. 11 replies.
02-27-2011 6:45 AM
HVD
- Joined on 02-21-2009
- Posts 33
BM5/BS5 don't go "powersave mode" anymore?
I have experienced for a while that my BS5 is alway "awake". When I turn it on it is ready to select/play music in 1-2 seconds even though its been in standby for some time. Normally it takes about 8-10 seconds before it is ready to be used if it has been in standby for some minutes.
Any body have the same change. Is it an update?
Does it still go in "low power consumption mode" (standby)?
It seen like it now works like selecting "sleep mode" on WIN7!
Cheers
Henrik
BS5/BM5, BL3, AVANT 32", BL8000
HVD
- Posts 33
Re: BM5/BS5 don't go "powersave mode" anymore?
Its connected via LAN (hard wire), and I haven't changed anything on my hardware setup, but my BS just stopped going to powersave mode!
Henrik
stefan
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
I had the same problem some time ago. I just set BM5 to standby manually, via the switch on the back, disconnected it from mains for a minute and started again. Now the BM5 is going to standby mode again.
Stefan
Niederrheiner
- Joined on 11-06-2009
- Posts 35
Hello Hendrik,
i found some information about the latest SW-Relase (6.02), where the automatic diableing of the supsend mode in the SW 6.01 was reactivated....but not automatic changed
Solution (translated from German)
Open Service Menu, to change the settings of the suspend-mode:
SYSTEM SETTINGS – POWER SAVING – OFF.
Good luck, this should work
Niederrheiner.
beolion
- Joined on 10-20-2009
- Posts 245
I wonder, since the BM5 can be used as UPNP server, does this then mean that the BM5 always will be up running? Or are there any Wake On Lan on BM5?
There is something about B&O.....
stefan
- Posts 1,733
2x yes. If you activate UPNP server on BM5 it will stay up running, and yes, there is a Wake on Lan. My BM5 wakes up, when I start Parallels on my Macbook, which activates WIN XP and Beoplayer automatically. Beoplayer will be automatically connected to BM5.
Stefan
HVD
- Posts 33
Thx for the help. I will try to deactivate UPNP server on BM5 to make it go into sleep mode. The deactivation of "pawersave" or restart of BM5 didn't help, so I guess UPNP serve has to be turned of. It use to wake up ie. if I turned on my PC with Beoplayer. Now its alway "awake".
I'm not going to be home for some weeks, but hope it will work!
Henrik
hackel
- Joined on 05-23-2008
- Posts 156
I have the same problem and no solution at all ?? For me, the menu or unplug the power didn't work.
If someone find the way to activated the sleep mode, please tell us how you have done.
BV7-40, BL9, BL4000, BL2000, BV6-26, Beosound 5, Avant70
hackel
- Posts 156
I found a solution yesterday, in service menu, Service Settings - Music Server - NO.
HVD
- Posts 33
Thx Hackel for the solution, but.
It worked for a couple of weeks, and now the problem is there again. "Music server" selected off, "power save" is "automatic" which solved the problem last time, but now it started not going to "power save mode" without me changing any thing. There is no change to my BS5/BM5 setup or other network in my house. How can this suddenly change without any action from me and with the same seting??? Any body experience the same?
Henrik
HVD
- Posts 33
Hmmm. problem solved.
Power off, and reboot BM5 and the problem is solved. It seems like BM5 og Win XP is not that stable and needs reboot once in a while.
Henrik
Page 1 of 1 (12 items)
