Spiros: I think you should keep them. Not sure but might be repairable.
Frede could probably enlighten us on this?
There is a possibility to repair some of the speakers.
Specially the one’s with the cone failures, a very careful process can save some.
One of the most important restoration activities is to coat the cones with a special coating material. This will give all old speakers / drivers ‘new life’.
I think about 25% of the drivers have a broken coil and cannot be repaired.
A good deal of them has a low output and this cannot be repaired.
Anyway there is a chance one or more can be used, so please keep them or sell them to other Beovox 2500 Cube fan’s..
/Frede
Beolab 5000 - "If another amplifier sounds different then it needs repair!"
