Latest post 02-21-2011 5:59 AM by Jon. 10 replies.
Page 1 of 1 (11 items)
  • 02-13-2011 12:08 PM
    Beovox2500 tweeters
    I have finally completed my 2 sets of 2500 cubes. I was wondering if the tweeters that I have as left-overs can be repaired (still 6 ohms).
    Or can I throw it in the bin. Is the rest worth for selling (Ebay)?
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 02-14-2011 5:54 PM In reply to
    Re: Beovox2500 tweeters
    Martin (Dillen), can you help about the tweeter question? Nobody else seems to know the answer
  • 02-16-2011 4:34 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    I think you should keep them. Not sure but might be repairable.
    Frede could probably enlighten us on this?
    Best regards
    Spiros
  • 02-16-2011 5:48 PM In reply to
    Thanks Spiros, I think the rest of the experts here are Sleep
  • 02-16-2011 6:31 PM In reply to
    • Jon
    • Top 500 Contributor
    • Joined on 03-05-2009
    • Posts 138
    Hey Leslie,
    I would definitely keep them, just in case they are repairable, and you want the satisfaction of knowing they are completely stock.
    That being said, they look pretty haggard, with the diaphragms being torn and such. I bet it would be super easy to find a modern cone tweeter that fit and had fairly equivalent sound characteristics. All the research and money has gone into developing domes, cone tweeters are super cheap and haven't changed too much through the years. I bet the use, or maybe the lack of it, of ferrofluid in a modern cone tweeter would be the biggest difference between those old ones, and a modern set.
    Jon
    P.S. - I guess I didn't read your post thouroughly the first time. You've already completed the cubes, apparently. Sorry.
  • 02-17-2011 10:25 AM In reply to
    • classic
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    Spiros:
    There is a possibility to repair some of the speakers.
    Specially the one’s with the cone failures, a very careful process can save some.
    One  of the most important restoration activities is to coat the cones with a special coating material. This will give all old speakers / drivers ‘new life’.
    I think about 25% of the drivers have a broken coil and cannot be repaired.
    A good deal of them has a low output and this cannot be repaired.
    Anyway there is a chance one or more can be used, so please keep them or sell them to other Beovox 2500 Cube fan’s..Smile
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
  • 02-17-2011 10:39 AM In reply to
    If they are surplus to requirements, I would send them to Frede so that they might actually be used. Whether he would welcome this is another matter! Big Smile
  • 02-17-2011 10:48 AM In reply to
    Thanks guys, if somebody is interested, PM me!
  • 02-18-2011 1:37 AM In reply to
    Jon:
    Hey Jon, that's the whole issue, you hardly can't find them in the original size that would fit properly. Spiros did an attempt some time ago but did not succeed (isn't it Spiros?).
  • 02-18-2011 3:11 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    They are 6 Ohms impedance so practically impossible to match today.
  • 02-21-2011 5:59 AM In reply to
    • Jon
    • Posts 138
    Leslie:
    How big are they?
    Jon
