Latest post 02-15-2011 1:15 PM by ........... 15 replies.
Page 1 of 1 (16 items)
  • 02-09-2011 3:24 PM
    Unusual request...
    Hi fellow Beoworlders,
    I have a slightly unusual request, and I'm hoping someone can help me..
    I have an ST500 stand for an Overture. A picture is attached. My stand is missing the bit that sticks up on the top that stops your system from falling off if it gets knocked.
    I contacted B&O, but there is no spare part available. If someone else has one of these stands, could they possibly measure the size if this 'bit' so that I can make one myself. I just need the width and the height it sticks out.
    I'm guessing I could make one with a bit of dowel or similair?
    Any help would be much appreciated!
    Jonathan
    My B&O: 2009 Catalogue and Pricelist
  • 02-09-2011 3:42 PM In reply to
    Re: Unusual request...
    The hole should be there ain't it, so you can measure the diameter. The length is pretty obvious as it sticks out for about 20mm?Smile
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 02-09-2011 3:45 PM In reply to
    Can you not measure the depth and diameter of the hole in the underside of the Beosound/center??
    Regards Graham
  • 02-09-2011 3:51 PM In reply to
    I can, but it's more the length above that I need... If it's too short, the system may still topple over. If it's too long the system may not sit flush..
    I'd rather do it right the first time!!
  • 02-09-2011 4:18 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    I produced one from a uk radiator bleed tool - it was the correct diam and had a horizontal bar which needed shortening slightly - the length was also adjusted and eventually mounted on an mxstand - think i mail you pics, the ouveture is the mountedat about 45' to the fronyt edgw and the rotated to line up, the spiggot prevents the ouverture from being dislodged
    If my workshop was up and running I'd make and send you one however currently thats another story
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 02-09-2011 7:52 PM In reply to
    Leslie:
    It looks a lot more than 20mm...
    Am I the only one here who has one??? I know I could measure holes, but I'd rather have the actual measurement of the piece itself..
  • 02-10-2011 4:17 AM In reply to
    • majand
    • Not Ranked
    • Joined on 02-26-2008
    • Helsinki
    • Posts 72
    • Gold Member
    jldmelb:
    Leslie:
    I have the thingy at home. I'll try to remember to measure it tonight.
    Pekka
  • 02-10-2011 4:29 AM In reply to
    I'll call my brother and ask if he can measure the one he's got.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 02-10-2011 4:33 AM In reply to
    It's 37mm tall with a diameter of about 10mm.
    -Andreas
  • 02-10-2011 5:30 AM In reply to
    Hi there - I have one of these left over from a BS3000 pole stand which had been used in conjunction with an STB BS4 conversion.
    Being the squirrel that I am, I kept the top plate including locating lug which I am sure is the same part as above.
    It's yours if you send me your address....
    HTH
    Llewelyn
  • 02-10-2011 7:20 AM In reply to
    Use part no 2993045 from the pole style stand, this should help!
  • 02-13-2011 6:22 PM In reply to
    Llewelyn:
    HTH
    Llewelyn
    Thanks for your offer! I sent you an email..
  • 02-13-2011 6:23 PM In reply to
    Thanks very much for all of your responses and generous offers!
    Beoworld is the greatest!!
  • 02-14-2011 8:30 AM In reply to
    does this help?
    BS1 x 2, BS 3, BS4, BS2000 x 3, BS2300, BS4000, BS9000, BL4, BL 4000 x 2, BL8000 x 2, BL2500 x 2, BL2000, Beocom 2, Beocom 6000 x 4, Beocom 1401 x 4, Beocom 1600 x 2, Beocom 2500 x 4, Beotalk 1200, A9 Keyring, Beo4 x 8, Beotime, Bottle Opener
    2011 Wish List: BL3500, BL6000, BL5, BL9, active link, BS5, Beo5
  • 02-14-2011 8:32 AM In reply to
    here's another from the top
  • 02-15-2011 1:15 PM In reply to
    Hi Jonathan
    Just to let you know I haven't received any emails from you re the above yet - Try resending or messaging me on here if you like?
    Cheers
    Llewelyn
