One of them motorises the TV, the other, the 3 drawer cabinet.  Obviously if the cabinet is motorised, it will work with either 28" or 32" regardless of type number (all you have to do is choose the correct rear cable cover for the cabinet).  However as Keith quite rightly says, the use of the motorised base for TV movement only, is limited by type number.
