Latest post 02-03-2011 4:02 PM by Leslie. 5 replies.
Page 1 of 1 (6 items)
  • 02-02-2011 5:52 AM
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Motor for CD door on BC 9500
    Bit of a long shot, I know, but if you don't ask.........
    Cheers
    Nigel
  • 02-02-2011 4:56 PM In reply to
    Re: Motor for CD door on BC 9500
    Hi Nigel,
    I think I have a BC9000 motor. Is that the same as BC9500?
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 02-03-2011 5:40 AM In reply to
    • h1npw
    • Posts 776
    I'll ask my dealer!
    I'll get back to you soon!
    Does it have it's 2 screws that attached the motor to the mounting plate?
    Cheers
    Nigel
  • 02-03-2011 1:40 PM In reply to
    Just read your thread about the glass panels. The motor can be sourced by your dealer so I won't have to break up my BC9000 parts?
  • 02-03-2011 3:47 PM In reply to
    • h1npw
    • Posts 776
    Hi Leslie
    Certainly wouldn't want you breaking up a good Beocenter just for me!
    I'll check with the dealer tomorrow.
    Cheers
    Nigel
  • 02-03-2011 4:02 PM In reply to
    Last time I bought a new motor for a BC2500 which cost  me 31 euro. Yours should be in the same range I guess! Anyway, let me knowSmile
