Bit of a long shot, I know, but if you don't ask.........
Cheers
Nigel
Hi Nigel,
I think I have a BC9000 motor. Is that the same as BC9500?
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
I'll ask my dealer!
I'll get back to you soon!
Does it have it's 2 screws that attached the motor to the mounting plate?
Just read your thread about the glass panels. The motor can be sourced by your dealer so I won't have to break up my BC9000 parts?
Hi Leslie
Certainly wouldn't want you breaking up a good Beocenter just for me!
I'll check with the dealer tomorrow.
Last time I bought a new motor for a BC2500 which cost me 31 euro. Yours should be in the same range I guess! Anyway, let me know
