1st March February 2012
Latest post 02-01-2011 6:43 AM by Chris. 7 replies.
01-31-2011 5:23 PM
Chris
- Joined on 03-19-2010
- Corbridge, UK
- Posts 353
Well i proudly shot of down to London today to pick up my Beovision 26 HD ready, and ended up getting home and finding out it was a Beocentre 23(with DAB module but no HDMI slot).
After you finish laughing here's a question. It does have a DVI connection at the back, can i connect this to SKY HD and watch the appropriate signal? I am aware i would need to run the audio independently. Please help
A Beovision 10-40 in black and red fret on order, Beo4, Beo6, many A8's, a pair of white and yellow Form 2's, Beocom 4, 28 inch Avant RF DVD, Apple TV and a wife that loves this stuff as much as i do!
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
Yes, you can use the DVI for the HD signal and do the Audio seperately. However, having a DVI socket doesn't always mean there's something actually behind it. Go into the DTV settings and see if it gives you the option of DVI-I...
Lee
PS - I do hope you knocked the seller down on price !!
9 LEE
- Moderator - UK
- Posts 5,223
You can go into the setup menu and change those you know! Just highlight them, then scroll through the options.
In fact, try STB - preferably STB(DTV) if it gives the option.
Lee
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
Keep in mind - early models of the 6-23/26 were NOT HD READY!
Without an upgrade with the HD-ready kit - only non HDCP (non copy protected) video content, e.g pictures from your computer can be displayed - but NOTHING DELIVERED by a BluDisc or a HD-Cable/Sat receiver ...
Add "PC" to your Beo4 "LIST" and try to access the DVI-Input - it should be an DVI-Integrated input and should handle VGA as well as DVI signals.
4 digit Type# or the Ser# of your TV would help ...
Chris
- Corbridge, UK
- Posts 353
Sorted out and refund due shortly. Thank you to everyone for doing the research etc. Picking up an HD model on the way home, and its a 26!!!
Don't trust old grannies
Page 1 of 1 (8 items)
