Latest post 02-01-2011 6:43 AM by Chris. 7 replies.
Page 1 of 1 (8 items)
  • 01-31-2011 5:23 PM
    • Chris
    • Top 200 Contributor
    • Joined on 03-19-2010
    • Corbridge, UK
    • Posts 353
    • Gold Member
    Nightmare!!
    Well i proudly shot of down to London today to pick up my Beovision 26 HD ready, and ended up getting home and finding out it was a Beocentre 23(with DAB module but no HDMI slot).
    After you finish laughing here's a question. It does have a DVI connection at the back, can i connect this to SKY HD and watch the appropriate signal? I am aware i would need to run the audio independently. Please helpUnsure
    A Beovision 10-40 in black and red fret on order, Beo4, Beo6, many A8's, a pair of white and yellow Form 2's, Beocom 4, 28 inch Avant RF DVD, Apple TV and a wife that loves this stuff as much as i do!
  • 01-31-2011 5:36 PM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Re: Nightmare!!
    DVI is only for picture... So... You have to run the audio independently...
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Nightmare!!
    Yes, you can use the DVI for the HD signal and do the Audio seperately.  However, having a DVI socket doesn't always mean there's something actually behind it.  Go into the DTV settings and see if it gives you the option of DVI-I...
    Lee
    PS - I do hope you knocked the seller down on price !!
  • 01-31-2011 5:53 PM In reply to
    • Chris
    • Corbridge, UK
    • Posts 353
    • Gold Member
    Re: Nightmare!!
    No, V-mem...stb....v.aux...decoder!!!
  • 01-31-2011 6:02 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Re: Nightmare!!
    You can go into the setup menu and change those you know!  Just highlight them, then scroll through the options.
    In fact, try STB - preferably STB(DTV) if it gives the option.
    Lee
  • 01-31-2011 8:58 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Nightmare!!
    Keep in mind - early models of the 6-23/26 were NOT HD READY!
    Without an upgrade with the HD-ready kit - only non HDCP (non copy protected) video content,
    e.g pictures from your computer can be displayed - but NOTHING DELIVERED by a  BluDisc or a HD-Cable/Sat receiver ...
    Add "PC" to your Beo4 "LIST" and try to access the DVI-Input - it should be an DVI-Integrated input and
    should handle VGA as well as DVI signals.
    4 digit Type# or the Ser# of your TV would help  ...
  • 02-01-2011 2:49 AM In reply to
    • Chris
    • Corbridge, UK
    • Posts 353
    • Gold Member
    Re: Nightmare!!
    Thanks everyone. Will ask trader to come up and remove, and a refund!
  • 02-01-2011 6:43 AM In reply to
    • Chris
    • Corbridge, UK
    • Posts 353
    • Gold Member
    Re: Nightmare!!
    Sorted out and refund due shortly. Thank you to everyone for doing the research etc. Picking up an HD model on the way home, and its a 26!!!
    Don't trust old granniesEmbarrassed
