Latest post 01-30-2011 5:03 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 01-30-2011 2:05 PM
    Beovox S50 tweeter defunct
    Hi have refoamed the speakers and they work beautifully, but one tweeter doesn't work, is there a simple test to check the tweeter itself? Help please,
    Steve
  • 01-30-2011 3:04 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beovox S50 tweeter defunct
    You can put an ohm-meter across it and check for continuity.
    Expect something like 4-6 ohms if measured out of circuit.
    Alternatively, swap it with the tweeter in the working cabinet and see if the
    problem moves with it.
    I may be able to supply a good used original tweeter if you need.
  • 01-30-2011 3:47 PM In reply to
    Hi martin, have tested it and it is dead. How much for a replacement please plus shipping to UK?
    Steve
  • 01-30-2011 5:03 PM In reply to
    • Dillen
    • Posts 5,008
    Steve, you have a PM.
