        1st March February 2012
	    Latest post 08-15-2011 11:34 AM by  elephant. 27 replies.
								        01-30-2011 12:56 PM
									        hotknife
								                - Joined on 02-03-2008
								                - Solingen/Germany
								                - Posts 552
										    Do rear speaker make sense in my setup?
										    Hi guys,
  I was wondering if you please could tell me your suggestion regarding a pair of rear speakers.
  left/right from BV8-40 a pair of BL8002 (all speaker are plugged into the DSS-system of the BV-8-40) left corner a BL2 couch 3.5 meters from BL8002/BV away couch placed straight to the wall
50% of the time, I listen to music from the BS4.
 I do not have space to place the rear speaker in the back of the couch (couch is placed to wall). So if I will add a pair of BL6000, they will stand left right to the couch (one speaker 30 centimeter beside me, other 1.5 beside me, but in the same line as my head),or if I mount a pair of BL4000, they will only be some centimeter behind me. A pair of BL3 are too much money.
  So do I benefit from rear speakers/do they make sense in my setup, or is it a waste of money and I will ruin the sound of BL8002/BL2?
  Forget suggestions like move the couch away (you do not know my wife).
  Thanks in advace.
  Take care
									    BeoVision 8-40, ATV2, BeoSound 4, Front BeoLab 9, Rear Beolab 4000 MKII, Beo 4
									        hotknife
								                - Solingen/Germany
								                - Posts 552
										    Re: Do rear speaker make sense in my setup?
										    DrDimitris,
already bought the BL2? I remember, you were struggling with the purchase of a subwoofer!
									        TheMajor
								                - Joined on 05-10-2007
								                - Tokyo
								                - Posts 251
										    You will see an improvement that is for sure with movies and TV. With music, that is down to your opinion. I prefer 5.1 for movies but 2 speakers for music.
If I were you I would try and move the couch. Not a way from the wall but more toward the center of the speakers. Even just 50cm would help. All you have to do it tell the TV how far the speakers are from the listening position and then the system will de/increase volume and delay speakers output by tiny amounts to make sure the sound hits you at the right time.
I just moved from 5.0 to 2.0 and really miss the rear speakers but it is the start of a move to go all B&O over the next few years.
									    Beosystem 7000/6500- Beolab 4000 - Beosound 1 - A8 - Earset 3 - Beo4
									        DrDimitris
								                - Joined on 04-25-2007
								                - Posts 560
										      hotknife:
DrDimitris,
 . Yes , i am still searching ( i wouldn't say struggling  ). I'm taking my time, although i would love to compare BL2 and BL11 in my home setup. Dealer's in Greece do not do that. (Except for my friend Spiros who has this advantage  ). Also i am 200 and 300 km away from those 2 dealers respectively. But as you already know, my mind is set on BL2. Will see. The charts on the DTS website i gave you above, are pretty informative. Did you check it?
									        hotknife
								                - Solingen/Germany
								                - Posts 552
										    Dear DrDimitris,
thank you for the link. Yes, I´ve checked  the homepage. Because I´m not
 able to remove the couch from the wall (my wife will 100% for sure kill
 me), the 5.1 setup will make sence (regarding to DTS homepage). But
would also be a problem, because the couch is not standing in the middle
 of the room. I only have 30 cm space left to the corner on one side. So
 one speaker (e.g. BL6002) would be 30 cm away, the other one round 3.5
meters.
Best, but most expensice solution would be a pair of BL3, fixed over my
head while sitting on the couch. Even a pair of second life BL3 are not
under € 2200 available.
Why don`t you buy a second hand BL2? If your are lucky, you can grap a
unit for under € 1500 (if have seen slighly used ones from the UK for €
1300 on ebay from a TV-room). If the setup won`t work (you will love it,
 I`m sure), you can resell it. With the DSS of your BV in combination
with the BL2 you are able to receive a very good result (not too "boom
boom").
									        DrDimitris
								                - Posts 560
										      hotknife:
Dear DrDimitris,
boom").
I am searching since some months now and i have never found such a price (1300Euro) for a BL2 on ebay. I also wait for something to come up on Lifestyle AV which i trust miles more than ebay.
									        hotknife
								                - Solingen/Germany
								                - Posts 552
										    DrDimitris,
you have to search on http://www.ebay.co.uk
Sometimes ebay search does not show all international offers. Below a finished auction for a good price on ebay.co.uk
http://cgi.ebay.co.uk/Bang-Olufsen-Beolab-2-Gray-Subwoofer-/230576835591?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item35af734c07
I do not think, following offer will reach € 1500.
http://cgi.ebay.co.uk/Bang-Olufsen-Beolab-2-Base-Unit-/120676815718?pt=LH_DefaultDomain_3&hash=item1c18e61366
									        hotknife
								                - Solingen/Germany
								                - Posts 552
										    Major,
the tiny BL4? I do not think they will keep the pace of my BL8002/BL2 front setup??? But wall mounted they look of cause great.
									        TheMajor
								                - Tokyo
								                - Posts 251
										    I had a set of Beolab 4 PCs and they were impressive. It was just and idea but as they are not too expensive and because they won't be working too hard as you will be sitting close to them and they will be rear speakers they may work pretty well. I wouldn't use them with music too much. Just an idea but people usually don't mention them that much for some reason but they are good speakers for their size.
									        hotknife
								                - Solingen/Germany
								                - Posts 552
										    Made two photos, so you are able to check if a pair of rear speaker make sense.
Living room has 22 m2.
									        symmes
								                - Joined on 04-21-2007
								                - Freedonia
								                - Posts 290
										    I think rear and/or surround is the best use of BeoLab 4.  3 mounting options.
									        hotknife
								                - Solingen/Germany
								                - Posts 552
										    O.k. symmes,
your mounting options, please.
									        macjonny1
								                - Joined on 11-08-2009
								                - Posts 355
										    Why are you set on mounting the speakers behind you with your couch against the wall?  Many would recommend that you mount the surround speakers on the side walls pointed at the couch.  If you use BL6000 I would mount them as well as the BL4000
									        symmes
								                - Freedonia
								                - Posts 290
										      hotknife:
O.k. symmes,
Floor stand, wall bracket, and ceiling bracket used as a wall mount.
									        Harry2008
								                - Joined on 11-09-2008
								                - Netherlands
								                - Posts 252
										    Giving your setup, I should really consider or try if possible, the BL4's. My sitting area is more or less the same as yours, aprox. 3,50 by 4,50 meter and i am using the Beolab 4000 as rear speakers. Sound is very nice, however in movies they are not used as much as you would expect. Or better formulated... the BL4 will probably deliver the same sound quality for movies given the size of the room.
I think a combination of BL4 with a Beolab 11 would bring you more benefit while staying within a certain financial boundaries.
I think I would mount the BL4 either at the wall or at the ceiling.
									        hotknife
								                - Solingen/Germany
								                - Posts 552
Hi guys,
still have the wish to upgrade my stereo-setup to a surround-setup (my wife not). Please take a closer look at the front and back of the living room. In the past days, I have read all articles regarding rear speakers and mixing ALT-speakers with non ALT-speakers. Even a pair of used BL3 are hard to find under € 2000 and I do not want to burn a big hole in the wallet because I´d like to buy a new B&O telly in 2011. So I`m struggling with given circumstances (room size 22m2 and couch place to the wall) to find the best rear speaker solution for me. I think a pair of used BL are fine.
Option 1: Pair of BL6000 placed left and right of the couch, fixed will wall brackets (I do not think it is working pretty good, because they will point toward the BL9 and not toward the listener.
Option 2: As above, but fixed with wall brackets not at the rear wall, but on the side, pointing towards listener (also not pretty good, because one speaker round 3m away, other speaker only round 30cm).
Option 3: Pair of BL4000 placed on the wall behind the couch (do not think it will work, because my head will be to close.
Option 4: Pair of BL4 (even worser the BL4000 because BL4 incl. wall bracket will point round 30cm into the room, BL4000 only round 12cm).
Option 5. Pair of BL3 paced left and right on the litte phone furniture and CD-rack or fixed with wall brackets (original B&O or better stbbrackets).
Options, option. I`m struggeling with position, size of speaker, ALT + non ALT.
Any B&O addicted also having the same problems? Buy the way, keep in mind, I will not buy new furniture to optimize my "living situation" in the room.
Take care.
									        quader
								                - Joined on 08-03-2007
								                - West Yorkshire, UK
								                - Posts 89
										    You could fix the BL8000 on a wall bracket and angle the speakers towards
your listening area
I have all 4 on a wall but 2 angled
									        Heribert
								                - Joined on 08-06-2009
								                - Austria
								                - Posts 592
										    6000 but standing on the floor turned to your listening position. I like my 6000 quite a lot - slim speaker with good sound.
									    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
									        DrDimitris
								                - Posts 560
										    As i also use them in my setup, i think a pair of BL4000's will be perfect. Far more versatile and since they will be wall mounted, the bass will be excellent. But since the couch is directly attached to the wall, i would have mouted them firing down towards your sweet spot.
Like that:
									        Rookie
								                - Joined on 07-02-2009
								                - Posts 149
i think that's a "no brainer" ... option no.5 is the way to go ... the ALT of the BL3 will serve you best as a rear.
The BL4000 wall mounted looks like a mailbox to me ... sorry.
Best regards
									    BV 7-40 BR ... Beolab 5 front ... Beolab 8000 rear ... Beolab 2 Sub ... Apple TV ... Apple NAS ... Beosound Ouverture  ... Technisat HD8-S ... Sonos ZP 90
									        hotknife
								                - Solingen/Germany
								                - Posts 552
										    Rookie,
why not? If they were only black or gold. But red and also placed "wrong" side, I think they look like a little artwork. I like if somebody use things the other way, not as everybody. Good job Dr.redBL4000.
Rookie,
do you think, a little pair of ashtry BL3 in red look much better placed in the mittle of my wall?
									        DrDimitris
								                - Posts 560
										      hotknife:
Rookie,
Rookie,
Hahahaha. Sorry if i was misinterpreted. Although i like red, my BL4000's are the classic alu with Black frets. I posted the picture to give an impression of a down firing BL 4000's pair. Not to hint you on the color selection.   Sorry for that. But if we want a more professional opinion on color for your setup Hotknife, when you decide the speakers than we can ask my SWMBO, who is an interior designer.
