Yes I did, just that I had the beosystem with the back / connections facing me so I went the easy way and thought I could remove the back plate without unplugging the screws on the other ends (top and side) of the chassi ;)
Anyway. I replaced the chip, I now see a new list. I accidently ordered the wrong chip. I got the motorola vip-1910 and the chip has the codes for motorola 1920. I got the 8344784 chip.
I have attached the ir remote on the front of the digital-tv-box exactly where the ir-reciever is, I have put a scart at the av connection and named it stb(dtv) in the menu. Still cant control anything. I can see the box´s picture when pressing dtv but nothing changes when I press control buttons lik up/donw or numbers or anything...
What am I doing wrong?
I must be the most unlucky person on earth if the 1920 code cant do anything on the 1910 box. The remote controls are almost identical...
