Well, i've had enough of Bang & Olufsen A8's.
But, before you all recoil in horror, there's a reason...
Not every time i go running - but i'd say about once a month, the sweat gathers in the foams and ends up ruining one or other of the drivers. Either that - or if it rains, the rain water does the same thing. I remove them and dab the water off gently with my running top as i go, or remove the sponges and leave the A8's to dry on a warm radiator when i get home - but alas, the damage is done and another pair of A8's get relegated to the 'to be fixed' drawer.
So, I'm now looking at in-ear earphones as the way forward - and the Shure SE535 seems to be the best. However, the Sennheiser IE8 is half the price and has rave reviews... There are a plethora of these type of earphones around and to be fair my head is spinning!
Some "BeoWorld Advice" is needed here. Help!
Lee
