Latest post 08-24-2011 4:19 PM by Mohawk. 3 replies.
Page 1 of 1 (4 items)
  • 01-16-2011 9:41 AM
    • root
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Posts 163
    • Silver Member
    glass door for beosound Century
    I am looking for a glass door for my century as well as one tweeter.
    Marcel
  • 08-17-2011 9:15 AM In reply to
    • Mohawk
    • Joined on 01-30-2008
    • Sweden
    • Posts 103
    • Gold Member
    Re: glass door for beosound Century
    Hi
    I needed a glass door for mine too. I ordered one from B&O. Remember to tell them your serial number since there are 2 doors available. Early BS Century have a glass door with a short metal bracket on the glass door, while later models have a larger bracket. See my attached pic. (Glass door for later models on the left and the bracket for early models on the right.)
    /Fredrik
  • 08-17-2011 5:51 PM In reply to
    • root
    • Posts 163
    • Silver Member
    thanks for the advice, but I ordered one some months ago and indeed, they asked for the serial number to make sure it fits.
    I see you posted a request for an active antenna and that you found one. I would be looking for the two brackets that sit on the back of the Century when there is no antenna mounted, maybe you don't longer need them?
    Marcel
  • 08-24-2011 4:19 PM In reply to
    • Mohawk
    • Sweden
    • Posts 103
    • Gold Member
    You got PM
    /Fredrik
