thanks for the advice, but I ordered one some months ago and indeed, they asked for the serial number to make sure it fits.
I see you posted a request for an active antenna and that you found one. I would be looking for the two brackets that sit on the back of the Century when there is no antenna mounted, maybe you don't longer need them?
