Hello everybody,
I was quite proud of having linked my computer to my BV7-32 Mk1 to my computer and use is as a great computer screen. It was quite some work, but with enough trying, I made it.
The problem is that it does not work anymore. I thought I just had to start the TV first and then the computer ( with the right resulution), but suddently this is not the right thing anymore. I have the same problem in both linux and windows, I tried every possible start sequence. I set the computer on PC or PC-AV when it is present, the connection are on AV4...
Does anybody who really master this have an idea?
Be seing you
François
