Hi
I have a question for someone with technical knowledge.
If two Beovox speakers are to be installed, a Beolink passive is needed (with amplifier included), right? So far no problem. I also have one passive noname loudspeaker in a bathroom ceiling. I am told that this also could be used in the same zone as the two beovox speakers. This should mean that the all three speakers will play if you start the zone. Are there some method to be able to split the three speakers in two zones with just one Beolink passive? What I would like is to play the speaker in the bathroom without starting the two beovox speakers (or start the two beovox without the bathroom). It is not necessary to be able to have two different volume level in the two rooms.
Can this be solved without buying two BL passive?
Have a nice evening/morning
Clakke
