Latest post 01-24-2011 7:00 AM by PhilLondon. 5 replies.
Page 1 of 1 (6 items)
  • 01-12-2011 4:46 AM
    Linkremote won't connect to Linkplayer
    Hi
    Not sure where to put a support request on Linkremote - so I'll try here :-)
    I just got an iPad and downloaded the Linkremote. The iPad is connected to WIFI, which is the same WIFI my MacMini, which runs LinkPlayer, is on. But when I start the Linkremote app it just keep searching for Linkplayer - nothing else happens. Is there something I should make sure is enabled - some kind of accepting sharing etc.?
    The setup:
    The Beoport is connected to my MacMini in Option 0. I only have a Beolab 3500 connected via Masterlink. Linkplayer works just fine. :-)
    Best regards
    Jan
  • 01-12-2011 5:43 AM In reply to
    Re: Linkremote won't connect to Linkplayer
    Like every App on the App store, there is a "Support" link that send you back to the developer's support web page.
    Try disabling the Firewall on the Mac mini if you have one. If it does not help contact me. Go to LinkPlayer's help menu and you'll find an option to get in touch.
    Philippe
  • 01-12-2011 6:42 AM In reply to
    Oops, sorry! Forgot about the Support button on the App store.Whistle
    As far as I remember I do not have Firewall activated, but I'll check it, when I get home to night.
    BR
    Jan
  • 01-12-2011 2:47 PM In reply to
    Also LinkPlayer must be running :)
    Some Apps, like EyeTV's, will prompt you to start the server side if it is not running, but LinkPlayer has to be started first
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-12-2011 4:49 PM In reply to
    Hi
    Yep, I have Linkplayer running :-)
    @Phil: And Firewall is disabled. I haven't got mail installed on the Macmini, but will off course if neccesary or I'll send it from another computer. So what do I need to do, i.e. which information should I provide - console transcript?
    Thx in advance
    Jan
  • 01-24-2011 7:00 AM In reply to
    In linkplayer's preferences have you selected "respond to linkremote"?
