Hi
Not sure where to put a support request on Linkremote - so I'll try here :-)
I just got an iPad and downloaded the Linkremote. The iPad is connected to WIFI, which is the same WIFI my MacMini, which runs LinkPlayer, is on. But when I start the Linkremote app it just keep searching for Linkplayer - nothing else happens. Is there something I should make sure is enabled - some kind of accepting sharing etc.?
The setup:
The Beoport is connected to my MacMini in Option 0. I only have a Beolab 3500 connected via Masterlink. Linkplayer works just fine. :-)
Best regards
Jan
