Latest post 11-22-2011 4:27 PM by Vienna. 9 replies.
Page 1 of 1 (10 items)
  • 01-09-2011 7:26 AM
    • kimhav
    • Top 500 Contributor
    • Joined on 09-03-2007
    • Sweden
    • Posts 127
    Beolink Wireless 1 Hardware/Specification updates?
    Looking back on that the BW1 has been available for quite a while now; does anyone have information when and what kind of modifations has been made to this unit since released?
    Filed under: ,
  • 01-09-2011 9:43 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beolink Wireless 1 Hardware/Specification updates?
    The Type # for all BeoLink wireless from 2006 till now is 1780, indicating,  there are no
    hardware changes, it's just the SW changed August 2007 from  Mk1 >> Mk2
    It should be possible to update all units to current SW.
    SW update 2.1 is allowing ML-Mode in the Linkroom.
    SW 2.1 has been implemented August-2007 to all BeoLink Wireless 1 with Serial#  higher
    than 19956171.
  • 01-09-2011 11:29 AM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Excellent - Thanks for prompt answer!
  • 11-13-2011 4:32 PM In reply to
    How do you update the software of the Wireless? And once again, I do not have the privilege of going to "my dealer" since there isn't one any longer.
    Best Regards!
  • 11-13-2011 5:50 PM In reply to
    • Vienna
    • Posts 712
    kammeri:
    Update via PC & "Service Tool" avilable to B&O dealers / B&O service (centers) / B&O installers.
    IMPORTANT: You'll also have to update all your BeoLink wireless to the same SW version,
    otherwise connecting is not possible.
  • 11-16-2011 9:51 AM In reply to
    Vienna:
    kammeri:
    Okay, thank you!
    It is becoming quite hard to retain a loyal B&O fan since the dealer network is almost non-existent and B&O doesn't offer any online/DIY support for simple tasks as software updates.
    Regards
  • 11-16-2011 4:47 PM In reply to
    • Vienna
    • Posts 712
    kammeri:
    since the dealer network is almost non-existent ...
    Come on -  if you pack the Wireless 1 units properly it will be easy to ship them
    to the next dealer / service center for an update - using a parcel service like UPS / TNT / DHL / ...
  • 11-16-2011 6:43 PM In reply to
    • frog
    • Joined on 04-19-2007
    • Posts 191
    kammeri:
    I agree. Kit I bought a few years ago - I have been palmed off onto some 3rd party 'expert' company to maintain - this is really not what I expected from B&O. They need to get national service centres up and running as the dealer support isn't what it was.
  • 11-22-2011 4:14 PM In reply to
    Vienna:
    That might be true. However the point is - as Frog also commented - the service provided for B&O products is also here outsourced to a 3rd party. To be more specific a 3rd party which doesn't answer the phone nor reply your emails (not the best way to build up an entrusted customer service relationship).
    I still consider a software update (among few other B&O related things) being something to be distributed via the internet in the 21st century.
    Regards
  • 11-22-2011 4:27 PM In reply to
    • Vienna
    • Posts 712
    kammeri:
    Sorry to hear that, but my experience with my local 3rd party B&O service center in the Vienna region is
    completely different!   They answer the phone, reply mails and are doing a good job.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
