Hi
I have a Beo4 which has recently had reduced performance meaning that I have to point it at the TV for it to send a signal. I have never had to point a Beo4 in my life! I changed the batteries but that did not help so I had a look at the IR bulbs at the front with a digital camera and it revealed that only one of the two bulbs is working hence I assume the reduced performace. Everything else seems to be ok.
I poped into my local dealer today and he advised that it would be cheeper to buy a new one than send it away to be repaired!
I therefore ask is it just a case of changing the bulb or a PCB in the remote, is it an easy job to do myself (already had a quick look at the service manual on the site) and how much will it cost to do?
I note that it is about 4 to 5 years old and was probably one of the first of the DTV versions, I assume that this may mean a different part number that the one in the service manual for the PCB.
I hope someone can advise accordingly.
Regards
DaveL
