1st March February 2012
Latest post 01-04-2011 12:03 PM by PhilLondon. 10 replies.
01-04-2011 5:42 AM
Francois1er
- Joined on 12-13-2010
- Fribourg, Switzerland
- Posts 53
linking a beocenter 9300 and a beovision 7-32
Hello everybody,
I am trying to link my beovision 7-32 to my beocenter 9300 (in the same room) so that I can have the sound of the BV7 (which is linked to my computer, where most of my music is) on the BC 9300 boxes. Getting the sound of the BC9300 on the 7.1 of my BV7 would be nice, but just that.
I researched the forum for a solution, and the closest thing to an answer that I couldunderstood was:
AVANT Mastelink -> Converter -> AUX-Link BC auf AUX/TV
Both in Option 1
Of course this is for a BV avant, thus I am not sure it even applies to me.
Any help will be greatly appreciated
Be seing you,
François
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: linking a beocenter 9300 and a beovision 7-32
Which speakers have you got? Which remote are you using?
Philippe
Large48
- Joined on 06-24-2008
- London
- Posts 455
I think this is correct,
9300 - AUX Out - 1611 Convertor - ML Cable - BV32
And then set the various options, etc.
Train Hard - Run Fast - Hit to Kill!!!
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
Try downloading the configuration guide to confirm the setup
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Francois1er
- Posts 53
Hello
speakers: currently infinity, possibly soon beovox 3000, 4500 or 5000, or even beolabs, again 3000 etc. but this is less probable. I use a Be04.
François
PhilLondon
- London
- Posts 2,545
Ok, as you are using passive speakers, this setup is correct.
P.
Francois1er
- Posts 53
Hello Stotty,
are you reffering to the user manual, the reference/service manual or a third type of document? I have user manuals and a service manual for the BV7 (Mk1), and I am working slowly, very slowly, through them.
Be seing you
François
PhilLondon
- London
- Posts 2,545
No, it is a piece of software you can download from this site, but only if you are a paid member.
You tell it what you have and it tells you how to connect and configure it.
You setup is fine however.
Philippe
Francois1er
- Posts 53
Hello Philip,
many thanks for your quick answer. I suppose that if I have one day active ones, I will need a dedoubler on one of the powerlink, but otherwise I will still need the beolink (Type1611, I learned recently).
If you have any question about wine, do not hesitate to ask me
Be seing you
François
Fribourg, CH and Bordeaux, F
Francois1er
- Posts 53
I must say that this website in general, but the fora members especially, have been extremly helpful in the recent days. I will probably join it as a paying member soon. One thing that held me back is that it does not state in detail what is in the payer-only section, and this slows me instinctively.
Be seing you
François
PhilLondon
- London
- Posts 2,545
Yes, they should state more clearly what is avaiable in the download section.
Anyway, if you have some active speakers, you should connect all of the to the TV instead and set the TV in option 2 and the beocenter to option 0.
You'll gain surround sound and an easier way to switch between different speaker configuration.
You'll need to connect a powerlink cable from the Beocenter to the converter as well. But no need to split as there are no speakers any longer connected directly to it.
Page 1 of 1 (11 items)
