Latest post 01-04-2011 12:03 PM by PhilLondon. 10 replies.
Page 1 of 1 (11 items)
  • 01-04-2011 5:42 AM
    • Francois1er
    • Not Ranked
    • Joined on 12-13-2010
    • Fribourg, Switzerland
    • Posts 53
    • Gold Member
    linking a beocenter 9300 and a beovision 7-32
    Hello everybody,
    I am trying to link my beovision 7-32 to my beocenter 9300 (in the same room) so that I can have the sound of the BV7 (which is linked to my computer, where most of my music is) on the BC 9300 boxes. Getting the sound of the BC9300 on the 7.1 of my BV7 would be nice, but just that.
    I researched the forum for a solution, and the closest thing to an answer that I couldunderstood was:
    AVANT Mastelink -> Converter -> AUX-Link BC auf AUX/TV
    Both in Option 1
    Of course this is for a BV avant, thus I am not sure it even applies to me.
    Any help will be greatly appreciated
    Be seing you,
    François
  • 01-04-2011 6:01 AM In reply to
    Re: linking a beocenter 9300 and a beovision 7-32
    Which speakers have you got? Which remote are you using?
    Philippe
  • 01-04-2011 6:05 AM In reply to
    I think this is correct,
    9300 - AUX Out - 1611 Convertor - ML Cable - BV32
    And then set the various options, etc.
    Train Hard - Run Fast - Hit to Kill!!!
  • 01-04-2011 7:55 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Try downloading the configuration guide to confirm the setup
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 01-04-2011 10:18 AM In reply to
    • Francois1er
    • Not Ranked
    • Posts 53
    • Gold Member
    Hello
    speakers: currently infinity, possibly soon beovox 3000, 4500 or 5000, or even beolabs, again 3000 etc. but this is less probable. I use a Be04.
    François
  • 01-04-2011 10:21 AM In reply to
    Ok, as you are using passive speakers, this setup is correct.
    P.
  • 01-04-2011 11:44 AM In reply to
    • Francois1er
    • Not Ranked
    • Posts 53
    • Gold Member
    Hello Stotty,
    are you reffering to the user manual, the reference/service manual or a third type of document? I have user manuals and a service manual for the BV7 (Mk1), and I am working slowly, very slowly, through them.
    Be seing you
    François
  • 01-04-2011 11:50 AM In reply to
    No, it is a piece of software you can download from this site, but only if you are a paid member.
    You tell it what you have and it tells you how to connect and configure it.
    You setup is fine however.
    Philippe
  • 01-04-2011 11:53 AM In reply to
    • Francois1er
    • Not Ranked
    • Posts 53
    • Gold Member
    Hello Philip,
    many thanks for your quick answer. I suppose that if I have one day active ones, I will need a dedoubler on one of the powerlink, but otherwise I will still need the beolink (Type1611, I learned recently).
    If you have any question about wine, do not hesitate to ask me
    Be seing you
    François
    Fribourg, CH and Bordeaux, F
  • 01-04-2011 11:58 AM In reply to
    • Francois1er
    • Not Ranked
    • Posts 53
    • Gold Member
    I must say that this website in general, but the fora members especially, have been extremly helpful in the recent days. I will probably join it as a paying member soon. One thing that held me back is that it does not state in detail what is in the payer-only section, and this slows me instinctively.
    Be seing you
    François
  • 01-04-2011 12:03 PM In reply to
    Yes, they should state more clearly what is avaiable in the download section.
    Anyway, if you have some active speakers, you should connect all of the to the TV instead and set the TV in option 2 and the beocenter to option 0.
    You'll gain surround sound and an easier way to switch between different speaker configuration.
    You'll need to connect a powerlink cable from the Beocenter to the converter as well. But no need to split as there are no speakers any longer connected directly to it.
