1st March February 2012
01-02-2011 12:59 PM
Stan
- Joined on 04-17-2007
- Posts 593
Re: Which power link cables
Mk3 works for all speakers. However, my dealer recommends mk2 (thick cables) for longer runs ( >= 3 m) - even for the ice powered speakers (where the manuals say mk3). Against his recommendations, I went with a 3 m mk3 to for some BL4s that I have - because I wanted the thin cable because it is easier to hide - and haven't experienced any issues (didn't have any problems with the mk2 that he loaned me while the mk3 were ordered), but then they're bedroom speakers (and BL4s) so I don't listen too critically.
Stan
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
Seanie_230:
Does mk3 work with all speakers
... exept BLb5s (switching to digital in if source is CD) and older speaker types like Pentas (display).
By the way, the new fully mounted, 5.5mm double screened type is much cheaper than the pevious 3,5mm Mk2 (now beeing discontinued) and the Mk3 version!
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
Vienna:
Seanie_230:
Agree with Vienna.
To cover all types you should use Mk2 or the new fully mounted type.(Sorry I don't have the part number)
Personally, I would ask Steve@soundsheavenly for his recommendation as he will be cheaper.
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
Hi there
Thanks for the replies
Im sure that when I used MK2 cables with the lab 9's there was a huge humming sound so the local shop lend me some mk3's until mine came in.
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
Vienna
- Posts 712
joeyboygolf:
Vienna:
Agree with Vienna.
To cover all types you should use Mk2 or the new fully mounted type.(Sorry I don't have the part number) Personally, I would ask Steve@soundsheavenly for his recommendation as he will be cheaper.
Sounds Heavenly is offering excellent products at reasonable prices !
But in this case - e.g. a 10m fully mounted PL-Cable the B&o original retails in Central Europe for 22 EUR ~ 18 GBP compared to 36 EUR ~ 29,99 GBP for Steve's version of the MK2!
(making Steve's version approx 65% MORE EXPENSIVE than the B&O "original" )
Prices for the 5,5mm fully mounted & double shielded PL-Cables have been rigorously reduced compared to the Mk2s some months ago ...
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Hi Vienna,
Thanks for your update on the prices, I was not aware that B&O had reduced their prices to this level. Please remember that I include free Worldwide shipping by Airmail within the prices, plus a 60 day money-back guarantee, whereas B&O prices are normally non-refundable and delivered to the store only. Additionally, the specification of the cables I offer is not the same as the originals. I use 24 carat gold plated contacts on the DIN plugs, plus oxygen-free copper wiring inside the cables for optimum signal transfer and sound quality.
However, I am happy to review the prices and I would welcome comments from other members of the forum if you have received any specific prices from your local store that leads you to think that I do need to change these.
Kind regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
Nickyg63
- Joined on 08-28-2007
- Nottingham
- Posts 628
Steve at Sounds Heavenly:
Hi Vienna,
Kind regards,
Steve.
Hi Steve, why not mirror B&O's quality and sell for cheaper and continue to sell your cables at the same quality and price! I personally know that your stuff is far superior and will continue to buy on your recommendation! Cheers Nick
P.s. I will text you an order for my dads and I have dropped my laptop today and bent that 3.5mm plug!
Vienna
- Posts 712
... there is nothing wrong with the quality of your products, your prices & your service !
Better product - higher price ...
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
Looking at this thread, I can't help wondering why B&O is bringing out a new fully wired Powerlink cable...
Could this mean the come back of displays on forthcoming BeoLabs ?????
Reunion Island is greeting you!
Page 1 of 1 (11 items)
