Latest post 01-04-2011 1:56 PM by Laursen. 9 replies.
Page 1 of 1 (10 items)
  • 12-30-2010 7:40 AM
    • Laursen
    • Not Ranked
    • Joined on 12-30-2010
    • Aarhus, Denmark
    • Posts 17
    Internet access from BeoMedia
    I have problems in connecting to the internet from my BeoMedia 1 (initial setup) I can connect to any network connected device in my internal setup, e.g. my NAS. When I try to connect to the internet e.g. www.bang-olufsen.com I can't get out in the internet zone. I can ping any device such as the NAS, my MAC etc. but I can't ping anything outside 'the house'.
    Any help would be much appreciated!
    Beovision 10-40 DVB-T/C/S2, MX5500, BeoSat, MX4000, BeoMedia 1, BeoCord VX7000, BeoSound Ouveture, BeoGram 3500, BeoLab 11, BeoLab 8000, BeoLab 3500, BeoVox CX30, BeoLink 1000, Beo4, Beo5, BeoSound 2, BeoCom 6000, BeoCom 1401, BeoTalk 1100, Beolit 606
  • 12-30-2010 3:33 PM In reply to
    Re: Internet access from BeoMedia
    Hi and a warm welcome Laursen,
    Unfortunately I do not own a BeoMedia 1 but anyway I would like to point you to the following.
    ad1) Have you double checked the internet preferences of the Internet Explorer of your BeoMedia 1? Maybe the Internet Explorer blocks all websites.
    ad2) Have you double checked if your router allows internet access to the IP Address given to the BeoMedia 1?
    Hope that helps.
    Cheers,
    Lars
    Beo Time, A8, EarSet3i, EarSet2, BC2, BC6, BL3, BL11, Apple TV1, BEO Ballpen, BL2000, BL3500
    Christmas 2010 Prize Draw 1st winner. BeoSound 9000 Mk3
    Thank you
  • 01-01-2011 3:09 PM In reply to
    What does the screen/panel tell you? Not registered?
  • 01-01-2011 3:22 PM In reply to
    I assume that The internet works on the Mac.
    Have you entered the service menu in the Beomedia?
    Connect a keyboard.
    Enter the menu (press R and after that a 9 or 0, (don't know as the successor BM5 I now have is a bit different).
    After that you should be able to check if the Beomedia got an ip address and sees the gateway address.
  • 01-01-2011 3:47 PM In reply to
    • Laursen
    • Not Ranked
    • Aarhus, Denmark
    • Posts 17
    The BeoMedia do have an IP address (can be seen from the gateway), I can access the gateway, and other devices in my home from BeoMedia, but not any external adresses, e.g. ping google.com don't work. I have a wireless keyboard connected.
    Cheers
  • 01-01-2011 3:49 PM In reply to
    • Laursen
    • Not Ranked
    • Aarhus, Denmark
    • Posts 17
    I don't remember to have registered elsewhere as in the BeoConnect.
  • 01-01-2011 3:58 PM In reply to
    • richtoy
    • Top 500 Contributor
    • Joined on 09-20-2007
    • Valkenburg, Netherlands
    • Posts 184
    • Gold Member
    Does NetRadio work?  If it does then the box thinks it is registered.  If it does not then you need to go through the whole process with BeoPlayer etc
    Richard
    Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
  • 01-04-2011 12:17 PM In reply to
    • Laursen
    • Not Ranked
    • Aarhus, Denmark
    • Posts 17
    I finally got it working - going step by step through the installation guide somewhat helped Big Smile some missing DNS settings was causing the problem.
    Thank you all for your feedback.
  • 01-04-2011 1:05 PM In reply to
    Good it is solved!
    That is why they say that usually the problem with any computer sits between the chair and the keyboard. I guess it applies to the Beomedia too.
  • 01-04-2011 1:56 PM In reply to
    • Laursen
    • Not Ranked
    • Aarhus, Denmark
    • Posts 17
    If nothing else works - read the manual Whistle I guess this also applies here.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
