Hello
I still continue to try to fix my beogram cd I changed the entire transport (laser & servo ) and the problem is the same, the spindle rotate and after then it stops and on the display appears the same strange char... No problem... I have the master pcb too where the transport works perfectly.
I have a little problem, the donor unit is a cd 460 (Philips) and on the main pcb there are some little differences, first the power connector is different and I solved this problem recabling the Phil one on the Beo power pcb BUT... there is another problem... The control panel on the Beo main pcb use only 2 pins called "I2C DATA" and "I2CCLP" and the other pcb (Phil) has a different connector and I have only tryed to find some similar point (I think to have found the two pins on the Phil).
Does anyone knows if the units control panel are compatible? I'm tempted to connect and power up the system but is this correct?
Thanks a lot
PS
I don't want to kill this Beo please!!!!
