Latest post 12-26-2010 3:16 PM by Spiros. 7 replies.
Page 1 of 1 (8 items)
  • 12-26-2010 2:23 PM
    Masterlink hi-fi
    Hi all,
    I have an overture. I know after this all of the beosounds came with masterlink, Was there anything before the overture?  I love the shelf type hifi's 8000,8500 etc
  • 12-26-2010 2:32 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Masterlink hi-fi
    Beocenter 2300/2500. But as in another post, Beosystem 7000 is one of the best along with the 4500
    Best regards
    Spiros
  • 12-26-2010 2:38 PM In reply to
    Thank you Spiros, I can always rely on you to help! Cheers Nick
  • 12-26-2010 2:41 PM In reply to
    • henrik
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Stockholm, Sweden
    • Posts 299
    The 7000 does not have Masterlink.
  • 12-26-2010 2:47 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    But easily connected and fully intergraded with the masterlink converter!!!!!!!
    Best regards
    Spiros
  • 12-26-2010 2:59 PM In reply to
    • BeoTom
    • Not Ranked
    • Joined on 02-09-2010
    • Texas
    • Posts 45
    Hi Nicky,
    I believe the BS4000/Overture was the first with Masterlink.  The 8000/8500/9300/9500, 4500, or 6500/7000 systems do not have masterlink, but can be be connected to a BeoLink Converter, which essentially gives it Masterlink.  If you like the shelf type systems, just get a Beolink converter to use with it, and you should be good to go! Smile
  • 12-26-2010 3:11 PM In reply to
    BeoCenter 8000 is an exception, this "cheapest" version did not have any LINK compatibility. And BeoCenter 2300 / 2300 can also be connected to a Masterlink system using a converter.
  • 12-26-2010 3:16 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    9000 as well, unfortunately!
    Best regards
    Spiros
